How to dl whole gal from this URL:
http://expose.hellfireangels.com/Face-and-Pussy?page=1
Download all from hellfireangels
Re: Download all from hellfireangels
Here are the project settings:
Starting address: http://expose.hellfireangels.com/Face-and-Pussy/
Target files: *.jp*
Site Exploration -> Regular site: Current directory and deeper
Filters -> Included URLs: Face-and-Pussy
Target files: *.jp*
Thank you! This working too goo, because downloading thumbnail, preview and full size images. How to get only full size images?
Well, you said you wanted the "whole gal"... Anyway, if you want only full-size image, then change the filter from "Face-and-Pussy" to "/var/albums/".
when I change to "var/albums", then don't downloading any image :(
That's strange. Works perfectly for me. Please make sure you applied correct filter. Simply copy/paste this one:
/var/albums/
That must be in the "Included URLs", not "excluded".
/var/albums/
Yes, I have this filter. After start in status showing downloads and then finishing without any files downloaded.
OK, here is a ready-to-use EPF project for you:
http://www.exisoftware.com/downloads/pi ... d-pusy.exe
Simply run the above file. It'll install a new project into the EPF project tree. Then run the project in the program.
Now downloading, I don't understand what I did wrong. Anyway thanks! :)
