Hi
Is it possible to just show a full size image, no thumbnail visible and then change that image like in a slideshow every few seconds or so?
Would prefer it if it was random as well.
changing full size image only
Re: changing full size image only
Yes, it's possible. You have to generate a gallery with a slideshow feature and then link to the "image000.html" page instead of "index.html" from your website. Also you can remove the "link back to thumbnails" in the built-in template editor. As for the random - currently it's impossible.
Thanks for that Maxim
Can I suggest a random feature be added for a future release?
OK, adding it to the to-do list. Thank you very much for the suggestion!
