Hi there,
I can't figure out to download from www.metart.com.
I have an paid account and I do use the manual login feature, still no dice for downloading members content.
Do you have experience with this site ?? Would it be possible only to download high resolution pics and/or movies??
Alternatively the high reso zip files.
I know some sites are hard to crack... this might be impossible??
Thanks in advance.
Jan
Is this site possible ??
Re: Is this site possible ??
Hello Jan,
OK, I can try to find settings for this site if you send me your user name, password and site starting address (because www.metart.com doesn't work) to support@exisoftware.com.
Hmmmm.... for some reason I can't send you a pm??
I am not putting pass and user in an open thread!
How do I send the info to you??
Kind regards
Jan
Kind regards
Jan
I am clearly a moron - plz disregard my later post!!jan1988 wrote:Hmmmm.... for some reason I can't send you a pm??
Kind regards
Jan
Jan
Just use email please ;-) support@exisoftware.com
