Downloaded from the website of the anti-hotlinking
Re: Downloaded from the website of the anti-hotlinking
1. In the "Target files" add "showimg.php" to the target files list.
2. In the "Save -> Naming" select "Use query string for file name" then check "Use value of this parameter for file name" box and enter "filename" in the corresponding box.
Worked just fine for me. Hope this helps.
zhangqing
Post by zhangqing »
The software you write is the best I've used. Fast. Easy to operate. One problem is that the search condition does not write.As http://www.cuthairbar.com/。Download pictures continuously for 24 hours. Will not end。Thank you.Your reply.
Here are the settings:
Starting address: http://www.cuthairbar.com/
Target files: *.jp*
Exploration type: Regular -> Entire site
Excluded URLs:
/ad/
/avatar/
That's it. You can add more "Excluded URLs" to increase download speed by excluding other addresses that don't lead to images.
