Website Help
DurkQ
Website Help
Post by DurkQ »
Trying to download all images from this website http://primejailbait.com
All I get is either 2 images and then it completes or an error saying the website returned a 404 error, I have tried different URLs and a bunch of different settings and I can't figure it out...
Please help!
Re: Website Help
That's strange. This site works with all default settings. I used the following starting address:
http://primejailbait.com/gallery/
And then added a few filters to skip ads, profiles and other unnecessary things. I added this project to the built-in online database into the "Erotic -> Teens" category. It's called "PrimeJailbait.com". You can download the project from the database and start it. You can also look inside the project settings to see what filters I used.
DurkQ
Re: Website Help
Post by DurkQ »
I have just tried the database download and after a short while got another error message, and clicked the report link to report the issue. I do not know if it is something I am doing wrong or not, but every other website I try seems to work fine...
EDIT:
I may have figured it out, It seems the website blocks the IP address for a short while if it receives too many requests too quickly, I deleted the project started again with only 2 simultaneous connections, instead of the 15 I normally use and it started working ok...
Thanks for your help
