Website says Hotlinking Protection
MSWAN
Post by MSWAN »
Trying to download pics from southerncharms.com
Get an error message that says Hotlinking Protection.
Disable your referring URL Blocking
How can I get past this?
Re: Website says Hotlinking Protection
Well, it seems to be working just fine with all the default settings. Anyway, I added a new project to the built-in database into the "Erotic -> Amateurs" category. Now you can download this project from the database and start it.
MSWAN
Post by MSWAN »
I tried using your project from the database and it is still giving me the error.
On what file? Can you give me the URL of the file?
MSWAN
Post by MSWAN »
It looks like it works fine on the preview pages...
But when I log in on the member side and try to run the program, that is when I get the error...
Any way I can PM you my login and password and you can try?
OK, send your login information to support@exisoftware.com.
MSWAN
Post by MSWAN »
email sent... Please let me know how to fix this issue.
Thanks.
OK, problem solved. Please download updated version of the program:
