error screen, slideshow stops working
gojeffie
Post by gojeffie » 26 Jun 2012, 15:54
I just installed your slideshow and have the pro version. I am running windows 7. The slideshow starts and works fine for a while and then it suddenly stops. I get an error message telling me an error has occurred and windows is checking for a solution. I guess none was found. I have no idea what the error was. The slideshow will then start again as it should and then I get the same error message and the slideshow stops. Any suggestions? Vicki
Re: error screen, slideshow stops working
Post by Maxim » 27 Jun 2012, 11:46
Do you use only local photos for the slideshow or let the screensaver download wallpapers from the Internet?
gojeffie
Post by gojeffie » 27 Jun 2012, 22:07
I only use local photos for my slideshow. I have not downloaded any wallpapers from the internet with this program.
Post by Maxim » 27 Jun 2012, 22:31
Hmm. This is strange. Have you tried re-installing the screensaver? It helps sometimes. Here is the link to the most recent version:
http://www.exisoftware.com/slideshow-sc ... _setup.exe
gojeffie
Post by gojeffie » 30 Jun 2012, 03:49
Sorry it took so long to reply. I wanted to let the slideshow run for a while. It is now working great. I should have thought to reinstall right away. Thanks for the help. Hope the slideshow gets a pan/zoom soon. It's the only thing missing. Thanks again. Vicki
Post by Maxim » 30 Jun 2012, 12:39
Glad I could help!
