Imgsrc.ru HELP PLEASE
Abeautim
Post by Abeautim »
Hey, i have a little question about Imgsrc.ru:
Is it possible to download ALL the albums of user at once? For example this one http://imgsrc.ru/main/user.php?user=maxsimys
If so, could you tell me how?
Re: Imgsrc.ru HELP PLEASE
First of all please make sure you have the latest version of Extreme Picture Finder:
Then download and install the imgsrc.ru - all user albums template:
And make sure you use no more than 3 simultaneous connections to avoid IP ban.
And here is the tutorial for imgsrc.ru downloads using templates:
http://www.webimagedownloader.com/how-t ... ru-albums/
Abeautim
Post by Abeautim »
http://imgsrc.ru/main/user.php?user=sj38257
This one. Why does not it download all the albums (except password protecteds) ?
You simply have to use the starting address
The rest of the settings are the same.
Abeautim
Post by Abeautim »
Yeah sir that's exactly what i did... But last time i tried it downloaded 61 pictures and before (in previous project with same adress) only 124 from ~319 non-passworded photos.
You have to add another "Included URL":
preword\.php
Also don't forget to enable the delay between downloads here:
and use no more than 2 simultaneous connections.
