Imagefap problems
Imagefap problems
I am having trouble with Imagefap when the ballery number only has 6 digits, when there aer seven numbers in the gallery url it wors perfectly, but there are a lot of galleries with 6 digits in the url, and then EPF goes through the motions but returns zero images. I have tried leaving one X in place and replacing the 7 X's with the 6 digits in included URls, I am using your downloaded template, please help, Thanks
Re: Imagefap problems
OK, give me a sample gallery address for the test.
hERE IS ONE THAT REFUSES TO WORK
http://www.imagefap.com/pictures/796936 ... hore-bitch
aPOLOGIES FOR THE WORDING OF THE TITLE !
OK, I've updated the imagefap.com template project. Please download and install it:
Now it'll process galleries with 6-digit IDs, plus it'll save not only JPGs, but also GIFs and PNGs.
Wow Maxim,
that was fast ! It woks great, thank you so much,
I definately WILL be buying this program, with support like this I am very impressed
Thank you
Thank you
