Hi Maxim.
I have another suggestion for your great screensaver:
I checked out your other program, "extreme picture downloader" and it seems to work great. What if you could integrate a possibility to make your own categories in the screen saver, based on websites the same way as in the picture download program? (with the option for minimum file size, and a option for placing small images on a random position on the screen)
thanks.
-Julemann
suggestion: custom categories
Re: suggestion: custom categories
Well, it will certainly make the screensaver much more complicated. I think you should do the following: download pictures with Extreme Picture Finder and then add them to Endless Slideshow Screensaver file list on the Local pictures tab.
And about placing small images on random position on the screen - this one seems to be great! Adding it to the to-do list! Thank you very much.
