Issue downloading alot of files.
5thElement
Post by 5thElement »
When I download pictures in large quantities, the download speed get slower the more files I get.
For example. The first 1000 to 5000 pictures, it goes very fast, then from 10.000 to 15.000 pictures, it gets alot slower for some reason.
I've checked all my stats such as CPU,RAM,HDD,Net speed and ect, and there all normal. So what can it be thats slowing the project down?
Regardless, thank you for a great product Maxim! It's really awesome.
Re: Issue downloading alot of files.
What kind of download projects you create? Do you use 1 starting address or you use a lot of addresses in one project?
5thElement
On my current project, I'm only using 1 address for the whole project. This one here - http://nik.bot.nu/browse.fu
I am currently at 38.000 downloaded images now and it's basically standing still.
Could I just pause the project, move the downloaded files to another drive, and resume? If that might help.
OK, what do you mean "standing still"? No new files are saved? Does the "Monitor" section at the bottom of main program window show the processed URLs?
