Image Properties
Welshdonga
Image Properties
Post by Welshdonga »
Hello
I discovered this software and it is one of the best packages that I have found to date. Its easy to upload and auto crop every picture to size perfect. But the only thing that I cant do is hide or take away the image property name example:
Market Street - 1989
#market_street_1989.jpg: (Image 1 of 274)
The problem is marked in red if I can stop this from being shown perfect, Is this possible and if so could someone help me.
Kind Regards
Phil Watkins
Re: Image Properties
Hello Phil,
Please tell me which template you are using for your galleries and I'll tell you how to fix it.
Welshdonga
Hello Maxim,
Thanks for your reply but I found out how to do it a hour later..All sorted now. Like I said this software to me is one of the best software that you can get I tried Coppermine and Zen Photo but this one does what it says on the box!
Keep up with the good work and is there a upgrade coming soon?
Regards
Phil
Yes, we're working on it.
