Command Line
Command Line
Does the software support command line usage and command line arguments?
Re: Command Line
Currently no. What arguments would be useful for you?
Re: Command Line
I would very much like to have the ability to do a web search from the command line. The following would be nice to be able to specify:
search phrase
dest folder
min image width
min image height
max number images
search mode (or just default to full-size images)
search engines (or just default to all)
The software would become less time-consuming and provide the ability to use in an automated type scenario.
search phrase
dest folder
min image width
min image height
max number images
Re: Command Line
OK, adding it to the to-do list.
