Download all image types
fechto
Post by fechto »
Hey,
I think the software is killer, but i can only download jpgs. Now,I'm running the trial version (I discovered it about an hour ago), but after reading a few threads it seems the paid version has a few more features, ie choose target files. Is this in the free version? If so, where?
Let me know pls!
Re: Download all image types
When you create a new download project click Next button several times instead of clicking Finish button right after entering the starting address. You'll see this page:
Here you can choose any file type to save. Plus you can manually enter any file type mask in the field at the bottom of the window, for example *.* to save ALL files from a target website.
Another way to add target files - in project properties window. Select your project in the project tree, use menu command Project - Project properties... and select the Target files section.
Here you can add file types to any existing project.
