Downloading all pictures from a forum-thread?
Aze
Post by Aze »
Hi.
First off, thank you very much for this great software. It really saves me a lot of time.
I have a problem though, which I can't find a solution for.
I need to download all pictures from a specific forum thread, containing multiple replies/updates (with new pictures). No matter what setting I use, it only downloads the pictures attached to the first post.
What I need EPF to do is download ALL the pictures from the whole thread. How can this be done?
Hope you can help me in this?!
Aze
Re: Downloading all pictures from a forum-thread?
Post by Aze »
Thank you for the support.
This is the site: http://www.fiberglassforums.com/subwoof ... w-box.html
It is a thread that consists of various replies/updates.
EPF only downloads the pictures from the first post, even though the post below consist a lot of pictures too...
Here are the project settings for you:
Starting address: http://www.fiberglassforums.com/subwoof ... w-box.html
Site exploration: Regular site, Follow all links
Excluded URL filters:
Included URL filters:
^http://www.fiberglassforums.com/subwoof ... x-\d+.html$
\.jpg$
Aze
Post by Aze »
YEAH!!! PERFECT!! I love this software even more now.
You made my day. Thank you so much for the great support.
Just for my reference, what have i "told" the program adding these lines?
The Excluded URL filter .* tells EPF to ignore (exclude) all addresses (except for those that match Included URL filters). The first filter
tells EPF to process addresses that start with
http://www.fiberglassforums.com/subwoof ... o-new-box-
then have any number of digits (\d+) and end with
.html
The second Included filter
\.jpg$
tells EPF to process addresses that end with .jpg.
Aze
Post by Aze »
OK. Thank you for the explanation. I think I get it now.
So when doing the same for another forum-topic, I will just ad: ^http://www.*ADDRESS*\d+.html$
right?
Well, it depends. You have to take a look at the actual addresses of the next pages of the thread to see what's changing. Then create a regular expression and add it to the Included URLs filter.
Alarm
Post by Alarm »
Hello.
I have a related question to this. There is a thread in a forum that i also would like to download images from.
It consists of something like 16 pages.
The url is:
http://www.mybike.gr/topic/27928-%CE%BF ... ge__st__60
The "http://www.mybike.gr/topic/27928-%CE%BF ... %B5%CF%82/" is the url of the entire topic
while the "page__st__60" are the pages.
The number 60 is random. So page 1 could be page__st__15 , while page 2 of the thread might be page__st__46 etc.
I added in the Extreme Picture Finder the following regular expression.
http://www.mybike.gr/topic/27928-%CE%BF ... 5%CF%82/[b](.*)[/b]
In order to download all the images from this topic.
Unfortunately i had no success as i could download only 7 images. Is there something i am not aware of ?
Thank you.
In case of forum threads you have to look for the common part of every thread page URL. In most cases the common part is a thread ID (in your case 27928). So you can do the following:
add Excluded filter
to exclude everything, then add
27928
to Included filters.
That's it. And make sure, the exploration is set to "Regular site", "Follow all links".
