Download parameters for Flickr
korgunal
Post by korgunal »
Firstly, Thanks for this well thought and amazing EPF.It is very helpful on my work.
My question is that, I want to download specific size of photos on the Flickr. On flickr, you can choose a diffrent sizes of photos for download. I only want to download the "original" sizes. The photostream I want to download is below.
http://www.flickr.com/photos/49176507@N08/
What parameters I should use ?
Thanks,
Re: Download parameters for Flickr
Here are the project settings for this photo stream:
Starting address: http://www.flickr.com/photos/49176507@N08/
Exploration type: Regular site, Follow all links (do not check the "Limit exploration depth" box)
Excluded URLs:
Included URLs:
/49176507@N08/\d+/$
/49176507@N08/page
/49176507@N08/\d+/sizes/l/$
That's it.
korgunal
Post by korgunal »
Hi Maxim,
Thank you for your reply. I configured EPF as you said and it worked. But, I can only download 1710 photos(Flickr shows 3050 pictures when you login.)
Do you have any idea about this?
Thanks,
korgunal
You never said it requires a login. You can check the "Manual login" box in the project properties ("Starting addresses" section) and let EPF download everything after you enter your user name and password.
korgunal
Post by korgunal »
Dear maxim,
You got me all wrong. I already selected required fields while strarting new project. (including manual login...) After the login, I can only download 1700 instead of 3050.
Thanks,
korgunal
OK, can you give a couple of image URLs that were not downloaded (along with page URLs where those images are shown).
korgunal
Post by korgunal »
Hi Maxim,
I was a little busy right here, sorry for late post.
I solved the problem on my own.
Right parameters should be like that. I downloaded all photos wtih this setup.
Thanks for your help,
korgunal
Included URLs:
/49176507@N08/\d+/$
/49176507@N08/page
/49176507@N08/\d+/sizes/o/$
djmakinera
Post by djmakinera »
korgunal wrote:Hi Maxim,
korgunal
Included URLs:
/49176507@N08/\d+/$
/49176507@N08/page
static\.flickr\.com/[^/]*/[^\_]*\_[^\_]*\_o\.(jpg|jpeg|gif|png)$
