How to convert multiple bmp files to jpg at the same time?
elizabethsmith
Post by elizabethsmith »
I have hundreds of bmp image files to convert to jpg.
Is there a fast way for this?
Re: How to convert multiple bmp files to jpg at the same tim
The latest version of Extreme Thumbnail Generator can do that easily. Simply add all your images and then click "Generate full-size images only" button on the "Generate" step. All converted images will be saved to the folder you specify on the "Gallery" step in the "Save gallery to" field.
