hi there,
not sure if anyone had this happen. the original images are TIF. once i generate the images i have them saving as JPG. it was fine i made 3 different batches, then it just started saving the files as TIF. just like that. no options have changed.
images not saving to JPG after resizing
Re: images not saving to JPG after resizing
This can happen if the original images are not modified by the program: not resized, no logo or text added. You can decrease the maximum image width and/or height on the "Images" tab of the "Options" step to make Extreme Thumbnail Generator resize the original images (and convert them to JPG).
