Reset Picture Database
AeonD
Post by AeonD »
Hey guys, I would like to be able to wipe out the search history entirely and start fresh. Is there a way to do this?
Re: Reset Picture Database
If you want to delete searches along with the downloaded images, then the only way is to delete them one by one. Sorry. We'll add the option to remove them all with a single click in the next version.
And if you just want to clear the searches list - you can do it in the following way. First, find out the location of the Extreme Picture Finder "Data folder". You can see it in the program options (menu command "Tools->Options"), the "Advanced" tab.
This is the folder where Extreme Picture Finder stores all internal data. You must open this folder in Windows Explorer (or any other file manager). There will be a sub-folder called "Searches". This is where all search projects are. Simply delete all files inside the "Searches" sub-folder and you're done.
AeonD
Post by AeonD »
Perfect, thank you!
