how to change generating folder
frustrated_in_OC
Post by frustrated_in_OC »
The Help documentation (Program settings/General settings) says it is possible to select the default gallery folder. However, after doing that, my html files and all the pieces get generated into the folder I originally downloaded Extreme Thumbnail Generator into. I cannot make the files go anywhere else.
Re: how to change generating folder
The "Default gallery folder" works for new folders only. If the gallery is already generated, then you can change its folder on the Gallery step. There is a field called Save gallery to. This is where you can change the folder where all generated gallery files and folder are saved. Take a look at the below screenshot.
After the folder is changed you have to re-generate the gallery.
frustrated_in_OC
Thanks but apparently you aren't understanding me. I do regenerate the files, that is how I know they are not going into the new folder. How do you tell the program where the generated files go? The Save Gallery To function is not working.
frustrated_in_OC
Ah, I opened and closed the program this morning, and now it works. Odd. I must have opened and closed the program seven or eight times last night. Thanks for the support.
