feature request regarding TEXT VIEW
EHALAHMI
Post by EHALAHMI » 29 Jul 2010, 11:31
It will be nice to have the following features:
1. Control over EXIF date/time format shown (like you have in Irfanviewer). For example I only want to see the date in dd/mm/yyyy format.
2. Different font size for different text element. I want to see the date from far away but file name, focal length etc. only from close as they are less important.
It will be great if you can add these features.
Re: feature request regarding TEXT VIEW
Post by Maxim » 29 Jul 2010, 12:46
Currently EXIF date is shown using Windows Regional Settings, so you can change the way the date appears in the screensaver by changing those settings.
Anyway, thank you for the request. Adding those features to the to-do list.
