When downloading from bunkr gofile those types of site a single threaded dump will constantly fail then attempt to redownload the videos. There have been many occasions where the download was at 99.9% and then... redownloading. I've changed the time out to allow for greater time. I've changed the size of the chunk when attempting a redownload. I've used a few different vpn connections but it always happens. New W11 install with the latest version of EPF. Any advice would be appreciated.
PS: Navigating to the media's url allows firefox to download it without any issues. Also not captcha related, tested several methods.
Redownloading + 99.9% Then Fails
Re: Redownloading + 99.9% Then Fails
Does it save the file in the end, after the redownload?
No it doesn't save it. It'll go in an endless loop unless I enable the maximum try. Where is the cache located, maybe i can manually pull it from there ?
Don't think so. Partial files are deleted once they fail. They are located inside the Temp sub-folder of the Data folder. You can see the location of the Data folder in the Extreme Picture Finder settings, Advanced section.
