Hi, is possible to make a template to download galleries from xiutaku.com?
Thank you
xiutaku.com
Re: xiutaku.com
If you only want the galleries, then create a project with the [ Exploration type ] of [ Current directory and deeper ] and you'll be fine. Not all websites require a special template; from most of them you can download with the default project settings or minimum configuration. Especially if we are talking about the photos. Videos are a different story...
Please try it and let me know if it worked for you.
Re: xiutaku.com
Yes, that does seem to work. Thank you
