new license update without reinstallation
dreamer29
Post by dreamer29 »
How can I update the license without uninstalling and reinstalling the program
thanks
Re: new license update without reinstallation
Yes, of course
There is no interface for that, but it's as easy as saving a file into a folder where the software is installed.
dreamer29
Post by dreamer29 »
can you give me a tip how I could best do it Maksym
Instructions sent via email. Did you receive the message? Did you update the license successfully?
dreamer29
Post by dreamer29 »
Thanks, yes it worked. I never had a text file in the folder where the license was.
Now you do ;-)
