Need the template for wall.alphacoders.com or other subdomains. I've searched the forums and applied whatever settings were discussed, but to no avail.
Maksym, could you kindly help please?
alphacoders.com - Template Required, please
Re: alphacoders.com - Template Required, please
What exactly would you like to download? "other subdomains" is too much. I could use some actual starting addresses.
Just wall.alphacoders.com would do great. If it could be done using search terms like "hollywood" etc. then even more wonderful.
Otherwise, just wall.alphacoders.com is fine.
Do you really want EVERYTHING from wall.alphacoders.com? Have you tried using built-in generic templates?
No, I don't want EVERYTHING. As I said earlier, if I could extract images using a search string that would be great.
And yes, I've read through your previous instructions in 2018 on the forum, but that's not working out.
Any help would be greatly appreciated.
OK, so what's the ACTUAL starting URL you want to use?
So, it's not even "wall.alphacoders.com" after all...
Yes, after all it isn't, a thousand apologies.
So could you kindly help with this, please?
