Sankakucomplex Template not working?
nemo888
Post by nemo888 »
Hi, I tried to save images from an artist in https://chan.sankakucomplex.com/ using the template from here: https://www.webimagedownloader.com/temp ... ownloader/ but I only get some images from that artist, 4 of them are and the rest are all random, very random.
The version I'm using is 3.63 and the artist is Sakimichan I'm using win8.1. I'm new using this app so maybe I'm doing something wrong so if any has the same issue or know how to make it work I will appreciate, thanks.
Re: Sankakucomplex Template not working?
What is the exact full address you try to donwload from? Do you need to sign in to the website to download the content? If it does - send me your login/password to support@exisoftware.com.
nemo888
Post by nemo888 »
the link I want to save is: https://chan.sankakucomplex.com/en/post ... sakimichan
mail sended, thanks
I've updated the template a little bit. But it looks like you need a newer version of the program in order to use it.
nemo888
Post by nemo888 »
Great!! 3.63 was the last version with win8.1 support? so I need to get win10 or up right?
Yes, latest versions require Win 10 or newer.
nemo888
Post by nemo888 »
Hi, I test the template and it work nice, but I noticed in the log viewer that it skip some images, why is that? can I fix it if I increase the time of download delay or something?, thanks
nemo888
Post by nemo888 »
Its any way to force or try to download only the skipped images?, thanks
What skipped images?
nemo888
Post by nemo888 »
it shows "429 - not found" but following the link its possible to get the image.
Also I noticed that it show a "200 - ok" on some addresses but the image in that link its not in the saved folder, I don't know it that count as skipped...
For example with this tag https://chan.sankakucomplex.com/en/?tags=himuro_kinu it show 71 result but it only save 3 images.
Or this other https://chan.sankakucomplex.com/en/post ... ire_emblem show 37 result but only save 4 images too.
