E-Hentai Template Download
crovax256
Post by crovax256 »
I think there might be a problem with the E-Hentai Downloader (v2) template. It seems like in some circumstances it only reads a certain number of galleries then stops, possibly due to an AD break on the page? I am not quite sure what might be the problem or how to resolve.
Example URL to try;
https://e-hentai.org/?f_search=artist%3 ... english%24
Template;
e-hentai.org downloader
When I run the above only 13 folders for each URL get created, however, there are closer to 25 galleries on the page. In the URL confirmation window i can see a large line break after 13 galleries almost like there is an empty space for an AD followed by the rest of the galleries.
Re: E-Hentai Template Download
The template was updated:
It supports the new pagination format now. You'll have to create new projects with the new version of the template. Existing projects are not updated automatically. Also, please make sure you are using the correct template when creating a project.
