Due to the adjustment of Bunkr, some videos are saved as files with names out of range. You would have to laboriously rename the videos individually including the file format
i test it with this link https://celebforum.to/threads/girlwithf ... and.32032/
This link is displayed in the download log when downloading a corresponding file
this here: https://taquito.bunkr.ru/-8803952700488 ... f%20range)
problem with celebforum.to Version 18 template
Re: problem with celebforum.to Version 18 template
What is the address of the bunkr page? I can't find a link on the celebforum thread.
https://bunkr.cr/f/pCIW1XUsghH4k
It can vary that some files are downloaded incorrectly
I have no idea why this is happening
Please re-download the template, create and run a new project and let me know if it worked for you this time.
Now it worked, but I will still do a lot of different tests, if I notice anything else I will let you know, thanks
