moving epf folder to new computer
When I move the epf files via settings, my old projects come to the program as a category. Projects with downloads do not appear in the program interface. Even though I did it according to the topic you opened in the forum, I read another friend's article on the forum saying that you need to put it in the project folder. The result is still the same, how can we solve this problem?
Re: moving epf folder to new computer
If you want to move your projects from the old PC to a new one - simply copy all the files from this folder on your old PC to the same folder on your new PC:
C:\ProgramData\Extreme Picture Finder\Projects
Then also copy the downloaded files if you want to.
