Template downloads images/videos only on the first page.
It does not view the remaining pages and completes loading.
rule34.xyz-template v3, is not working correctly
Re: rule34.xyz-template v3, is not working correctly
Thank you for reporting this problem. Please try the updated template and let me know if it works better now:
rule34.xyz downloader
The template v4 only loads a small part of the number of images/videos.
To make it work correctly, I added it to the Filters->Excluded urls
/\d+\.picpreview. This allows you to avoid downloading preview images.
I also added in Filters->Included urls /post/\d+$.
These changes allowed the template to work correctly. However, the template downloads duplicate images. Some images have a higher quality original. The names of the medium-quality images have "picsmall", high-quality "pic". I couldn't make it so that when uploading a high-quality image, the average quality wouldn't load.
Can you give me the exact URL you are using the template with?
To test downloads from different pages, I used https://rule34.xyz/holaraai.
To test uploading images of different quality: https://rule34.xyz/murakami_suigun
OK, I've updated the template a little bit. Please be sure to create new projects with the new template version. Existing projects are not updated with the settings from new templates.
I've never seen a single "picsmall" image. Do you sign in to your accout in the built-in browser to get them? I do not have a rule34.xyz account, so I never sign in. With this new template version I was able to get the exact number of high-quality images as stated on the website. For your URLs it's 24 and 388.
