ashemaletube.com
madnauseam
ashemaletube.com
Post by madnauseam »
Hi
I believe this template is not working anymore.
ashemaletube.com video downloader
Both tag/video/search immediately stop and return an error.
Thanks!
Re: ashemaletube.com
They added the anti-bot protection, so the built-in browser is now required. I updated the template to make it pop up when you start the project:
Whenever you see a behavior like that, open your project's download log. If your Starting address gives the HTTP error code 403 - try to see what's happening in the built-in browser. Check the [ Manual login ] box in the project properties and [ Restart ] the project. In most cases simply opening the built-in browser solves the problem.
madnauseam
I thought so, and I tried just that, but it also failed.
Did it work for you? I'm getting odd behaviour. Either it doesn't work or I have to find the address manually in the address list, when the popup window opens.
Ty!
It simply works for me, with any URL. You can try setting the User Agent from your browser:
My User Agent
It helps for some porotected websites.
