It seems the template download from other peoples/lists.
Tested: https://www.listal.com/list/beach-watch
It should download only 6 images, but the template seems to want to download every image on listal.com
I think they have changed something on listal.com
listal.com - template v5, is not working anymore.
Re: listal.com - template v5, is not working anymore.
Yes, looks like they did actually change something. Thank you for reporting the issue. I've updated the template. You are welcome to download it:
listal.com downloader
You will need to create new projects with the updated template. Existing projects are not updated when you install a new template version.
Please try it and let me know if it works better now.
Thanks, but it seems the problem still exist.
Still download other images.
Oh, they have different types of pages that show the full-size image now :( Let's see if I can fix it.
OK, please try the new version.
It seems v7 works.
Thanks.
Thanks.
