Hello Maksym!
Can you help me make a profile for erorate.com?
This site is a challenge since it hides the results of the search and limits it to 24 images. The problem is, there is no pagination meaning the only way to see more images that have something to do with the search is to click an image on the "similar" zone that appears below when clicking an image.
So far I got this:
Included URLS:
Excluded URLS:
tag/
image/
/w480-
/w240-
/w80-
/w768-
/w320-
/w640-
/w160-
64x64
explanation on the excluded: those are the first part of the filenames of undesired smaller resolution images. If you download without those, you download the same image in all those smaller sizes too creating dupes of lower res.
I haven't used "excluded page parts" because the whole site seems to use java and conceals the galleries.
Thanks!
erorate.com
Re: erorate.com
OK, I see. It's not difficult to configure Extreme Picture Finder to download "similar images" of any image on erorate.com. The real question is: when do you stop? Because for every "similar image," there are more "similar images". So, how do you decide when it is enough? Or is your actual goal to download everything erorate.com has?
Re: erorate.com
Yes, I was planning to manually shut it off once the 'similar' images are no longer similar by looking in real time what is being downloaded. If you somehow come up with a way to stop it automatically, it would be more than welcome, but due to the nature of that site I think there is no other way.
Re: erorate.com
Here is a template that downloads the related images along with the main search results or tagged images:
erorate.com downloader
I set the [ Exploration depth ] to 4 to limit the download scope to the first set of related images. So, you will have the main 24 images and then up to 12 related images for each of those main 24. If you want more - increase the [ Exploration depth ] in the project properties.
