Google search not downloading
smith
Post by smith »
Hi
google search not downloading files due to robotic captcha verification
can you help to bypass captcha verification
Re: Google search not downloading
You need to download this template:
google.com - custom image search template
and create a project with any google image search URL. For example:
https://www.google.com/search?safe=off& ... each&udm=2
When you start a project created with this template a built-in browser window will open allowing you to pass the CAPTCHA. After that the built-in search should work just fine.
