Tits in Tops
madnauseam
Tits in Tops
Post by madnauseam »
Will it be possible to have a Tits in Tops forum template?
For instance, getting the attachments from all threads in the forum (NSFW):
Code: Select all
https://titsintops.com/phpBB2/index.php?forums/tits-in-tops-social-media.1/&order=post_date&direction=desc
I sort of managed to build a generic template that goes through all threads and thread pages in a forum, but I believe it is only downloading image previews and not the image itself.
Thank you
Re: Tits in Tops
It depends on your settings, but I think you need to add the following filter to the [ Included URLs ] section of your template to make Extreme Picture Finder grab the attachments:
Code: Select all
index\.php\?attachments/[^/]+/$
Also, you may want to add
Code: Select all
/data/attachments/
to the [ Excluded URLs ] to prevent the download of thumbnails.
Plus, you need to sign in in the built-in browser, so checking the [ Manual login ] box is a must. But I think you've done that.
madnauseam
Re: Tits in Tops
Hi Maksym,
Thank you.
I'm unsure if it is working correctly. Is there some place I can submit the template so you can have a look, should you have the time for it?
Regards,
Re: Tits in Tops
You should test such things on one page. Use a thread page URL as your Starting address and update your template/project so that it doesn't crawl other pages of the thread or other threads. After you make sure it gets everything you want from one page - allow it to crawl other pages of the thread, then add the ability to crawl other threads and forums, if necessary. It's not that difficult.
Cheese001
Re: Tits in Tops
Post by Cheese001 »
I'm not so interested in this site but I also tried now to use your recommended settings just to download the attachments of a single thread like this:
https://titsintops.com/phpBB2/index.php ... y-m.88045/
but the program does not download them. It downloads photos from other threads even if I have excluded them using [ Excluded URLs ].
I don't know why.
Re: Tits in Tops
I just used my own advice and created a template with the suggested settings. It seems to work just fine with the thread addresses:
titsintops.com downloader
