Patreon Template works, but doesn't get everything
The Patreon Template acted kind of weird for me: I was able to login, and saw the page I wanted to download, everything seemed fine. However when I started the project, it downloaded a post from a different creator than I had put the page in for, then it downloaded 1 post from the user whose folder I used to start the project.
Re: Patreon Template works, but doesn't get everything
Hmm. They must have changed something. I'll need the exact URL you were trying to download from along with your account information. Please send this information to support@exisoftware.com (you can change the password before sending it to me and then change it back once the template is working).
I figured it out, when using the manual login, patreon starts you at the top of your list after you log in. I just navigated to the correct page and it's working great now, thanks anyway!
Great! Thanks for the info!
