It seems the log file is incomplete.
I recently used EPF on a directory with 400+ images, only ~half completed (verified in download directory), but the log only listed about 50 incomplete files.
Is there a way to maintain a total log, as well as reset/clear options?
log incomplete
Re: log incomplete
Why do you think the log is incomplete? Do you have saved files that are not mentioned in the log?
Re: log incomplete
I select my project and then Project>View download log...
The log did not contain 400+ items, maybe about 200 and listed only about 50 incomplete files when more than 200 were actually missing in the directory.
I have tried several different scrapes, and most times the log does not seem to list all data.
Is there any setting for log size or cache?
Re: log incomplete
If items are not in the log then Extreme Picture Finder did not find those items and you need to adjust your project settings to make the software find those files. You never sent the URL, so that's all the information I can give you.
