First of all, thank you for creating such a wonderful program.
Is there anything (even generic) to try?
Template for missav.com
Re: Template for missav.com
Is there a way to set it up using what I found out?
I need help.
I found out how to check the video address (m3u8).
You can type "window.source1280", "source842" in the console.
The access address is in the form of missav.com/video file name.
For example, if you access
missav.com/hunta-703, you will be redirected to
missav.com/dm58/en/hunta-703,
and in the console of that screen,
[window.source1280]
>> surrit.com/2e26fed1-914d-4edd-b696-8d8e5edd9776/1280x720/video.m3u8
[window.source842]
>> surrit.com/2e26fed1-914d-4edd-b696-8d8e5edd9776/842x480/video.m3u8
You can see it as above.
With that information, I used the "M3U8 Downloader" Chrome extension
and downloaded it.
I found out that it was downloaded normally.
Is it possible to make it into a template?
I need help.
[window.source1280]
[window.source842]
and downloaded it.
Yeah, I created a template that used all that information, but it turned out that their .m3u8 links are protected by Cloudflare :( Extreme Picture Finder can generate all those links, but it cannot donwload them :( Access denied. You can create a project in Extreme Picture Finder with any of those .m3u8 links and see the result.
Technically, you can use this template that I created for a single video, one after another, afrter a certain period of time... And it'll get you the .m3u8 file along with thousands of video "slices". So, I can post it, if you want.
Oh.. I see.
Thank you for your support.
