Can you create a downloader template for zoomgirls.net?
It's an adult site like erowall.com
zoomgirls.net downloader
Re: zoomgirls.net downloader
Habe you tried the built-in generic templates? Looks like the one called "Download all images from entire website" should work just fine.
It does not work well because it downloads unwanted images, such as images of the website design, logos, and other parts of the website.
OK, do you know how to filter them out? There are several different possibilities for that:
1. Use image size limits to save images only within certain size limits (you can specify the maximum or minimum allowed with and height).
2. Use the file size limits to download and save only files bigger than any given size.
3. Use [ Excluded URLs ] filters to prevent Extreme Picture Finder from crawling URL that match any given Regular Expression (take a look at the Download log to spot the unwanted addresses).
4. Use [ Excluded Page Parts ] to make Extreme Picture Finder skip certain parts of the page source when it's searching for new links in the source of a downloaded page.
That's what I use for the templates. For every template. And I'll be happy to provide help using any of the above methods. Just ask me specific questions and you'll get all the knowledge that I have.
I tried to do it, but there was nothing I could do.
I'm just a beginner.
OK, let's go through it together. What exactly did you try and was the result?
I tried to set excluded parts, but I honestly didn't succeed because I was inexperienced
Choosing an image size wasn't important and the size of the excluded links didn't help me.
But there are some things that can help:
The download address should look like this: zoomgirls.net/download
For example: zoomgirls.net/view-ekaterina-kulinich-1920x1080.html in here is a download link.
There was no original size, but this is about the highest size on the site.
But the site also has categories and a tag feature that takes a long time for someone like me to figure out how to configure the template.
Not as simple as erowall
It was a jpg image format
I hope you can help
I hope you can help
