Settings off screen
Settings off screen
When I disconnect my external monitor and open the Windows screensaver settings and from there open the Endless Slideshow Screensaver settings, the settings window seems to open on the disconnected screen. I can't see it. (Nor manipulate its location with Task Manager or the Windows key). Is this something you can fix or is it a Windows problem?
Re: Settings off screen
Yeah, it's most likey shown on the disconnected screen. It's fixable. Have you tried version 2.x beta? Des it have the same problem?
