Forum filter request
smartstud
Post by smartstud »
is it possible to grab only specific images from forum thread.
I need to scrape only reply photos with #id.
Like #post-1666209
Full URL is:
http://www.nudecelebforum.com/threads/j ... st-1666209
When I try to do that in extreme picture finder it returns all images.
Re: Forum filter request
The only way to do it is using the [ Excluded Page Parts ] to cut out the rest of the page text and leave only post(s) that you want. For this forum it can be done like this:
To: id="post-1666209"
This will remove all page from the text until the post that you want. If you want - you can add another Regular Expression to remove posts after another post like this:
To: (empty)
(Replace XXXXX with the actual post ID).
There is another example in this thread:
viewtopic.php?f=4&t=11296
