rule34.xxx template no longer downloads full gallery but only fraction (approximately 1/3). Do not know if there is also problem with videos but could be.
Could you please check it?
Thank you.
Rule34.xxx no longer downloads full gallery
Re: Rule34.xxx no longer downloads full gallery
Looks like the server won't allow fast downloads anymore. I added a delay between downloads and set the suggested number of simultaneous connections to 3 in the updated template. If it's not enough - use fewer connections and increase the delay in your projects.
few (about 30/220) pictures were downloaded twice but template seems to work now. Full gallery was downloaded (as far as I know) and even videos.
Thank you.
Thank you.
