Feature Suggestion - template update
The program already has the ability to check for updates so lets add the ability to download that update through the program, could be a right click option to add or adding a button next to the template
Re: Feature Suggestion - template update
Yes, it's in the to-do list.
do you have a posted list of features you plan on adding?
