en.girlstop.info
en.girlstop.info
What is a template for en.girlstop.info
Re: en.girlstop.info
You can use a built-in generic template for this website. You don't need any special one.
Hello !
First of, i want to thank you for this great software.
I wanted to say that the built-in template "Download Images From Single-Page Gallery" don't work well with girlstop.info.
Exemple A:
From the main page of an girl model like "https://en.girlstop.info/models.php?name=Milania-A"
It download only the 33 galleries thumbnails "450px_..." of this page.
Exemple B:
When entering one of the 33 galleries of this girl model like "https://en.girlstop.info/psto.php?id=146330"
It download thumbnails AND only some of the 16 full sized images available.
Exemple C:
Same problem as "exmple B" when entering multiple galleries pages at once in the project for this girl model.
I have tried the same process with another girl model and same problem.
Can we have a template please ? Or some tips ? Or Am I missing something ?
Thank in advance.
Have a nice day !
Exemple A:
Exemple B:
Exemple C:
Thank in advance.
Have a nice day !
I meant the [ Download all images from the entire website ] template. You can simply grab all images if you use that template. You can add 450px or /thumbs/ to the [ Excluded URLs ] filter if you don't want the thumbnails.
The [ Download all images from a single-page gallery ] template is meant only for the galleries. You cannot use it with an address that has links to the galleries. It has to be a page with direct links to the Target Files. So, I tried this template with the gallery address you provided and it worked perfectly. I added /thumbs/ to the [ Excluded URLs ] to get rid of the thumbnails and lowered the minimum file size limit a bit because full-size images are pretty small.
Plus, why would anyone use such a website with low-quality images and just pieces of the sets when there are websites like girlsreleased.com, nsfwalbum.com, sxypix.com, zzup.com, and others with 4K-resolution images and full photo sets? And there are templates for those websites.
Hello and thank you for your answer.
Thank for the tip about zzup.com and i really like it but the 2-4 seconds timeout to avoid being blocked by the website is really necessary or just for prevention ?
And can we do something to tell Extreme Picture Finder to not download images when the server is down or have a problem ? Because when it happens, the downloaded images are all .jpg white colored with a 404 error written in black at the center :s (And i checked to be sure that these images are available on the website so i guess sometime there is server side microseconds lag).
Those are still images. Extreme Picture Finder cannot tell if those are images with 404 drawn on them or a photo.
As for the delay - you can experiment with it. Remove it, change it. See what works for you. See for how long you IP is getting banned... Maybe it's worth it.
