I copied the downloaded wallpaper images I really liked to a folder, and then added that folder to my screensaver selection. The problem is that they never show or if I leave only that folder as selected I get an error message https://1drv.ms/i/s!Ah3aOTeCXQ_K4XTNfz6TzvabZTHa
Am I doing something wrong or is this not permitted and if so why?
Downloaded Wallpapers
Re: Downloaded Wallpapers
Do you use any file or image filters? Maybe you have filtered them all out?
Ah yes, so simple yet so effective. I looked and looked but the obvious illuded me. Thank you again Maxim.
