Can a template be made to download all the images and galleries within the favorites folder of an Imgur account?
I understand their new policy will delete a lot of favorited content on my account, and I am hesitant to click through it all and download it individually.
There are two ways to view the favorites, the main view that populates a grid with individual photos and galleries as you scroll, and also when you click on an item it will show a little window to the left of the content with a scrolling list of your favorited photos and galleries.
Here are the urls for the favorites:
https://imgur.com/account/favorites/
https://imgur.com/account/favorites/[image or gallery id]
Imgur Favorites galleries
Re: Imgur Favorites galleries
I'll need an account info (login/password) for that. You can send it to support@exisoftware.com if you want me to try to help you.
if its any help as I wanted to do this also.
use this template: https://www.webimagedownloader.com/temp ... ownloader/
change your link from
https://imgur.com/account/favorites/(random code)
to
https://imgur.com/a/(random code)
then download them like that :) will work perfectly.
i added all my links under one project so they are all under 1 folder called imgur.
although I'm not too sure if it worked with the videos as its only set to mp4 so @maxim is it possible to update this template and add more video formats?
to
Yes, of course, I can add them. Just tell me what formats are used by imgur, preferably with the addresses of the pages where I can see them (for the test).
Also, you are not limited to the formats specified in the template - you can change ANY settings after you create a project with any template.
I got it worked out, thank you both for your time!
