Tiktok Template
testuser420
Tiktok Template
Post by testuser420 »
Sadly im too dumb to figure out how to make a working template for tiktok.
Can anyone help?
Re: Tiktok Template
What do you want from tiktok? User videos?
testuser420
Re: Tiktok Template
All videos from a profile
If this works, im buying the software :D
Re: Tiktok Template
Looks like there is only semi-automatic solution for TikTok right now. You'll have to scroll the profile page down in the built-in browser manually and only then Extreme Picture Finder will download videos. Do you want it?
Cheese001
Re: Tiktok Template
Post by Cheese001 »
HI I would like to have it. :) Thank you.
testuser420
Re: Tiktok Template
Maxim wrote: 24 Feb 2023, 14:56 Looks like there is only semi-automatic solution for TikTok right now. You'll have to scroll the profile page down in the built-in browser manually and only then Extreme Picture Finder will download videos. Do you want it?
I found a different software that can do it without login, it can solve captcha and everything.
No idea how it works. Maybe you can reverse engineer how they do it.
All the scripts i found on github aren't working anymore too.
Re: Tiktok Template
Nah, that's not likely :(
testuser420
Re: Tiktok Template
If you get this and instagram without login working, your software would be the best.
Others do it, but only for a single website.
Impfove EPF and you make bank.
Please
Re: Tiktok Template
Looks like I spoke too soon about TikTok. I cannot get it to work even if the user scrolls the feed down. I'll have to research it deeper, but right now it looks like Extreme Picture Finder cannot do it.
simonrule
Re: Tiktok Template
Post by simonrule »
any update about tiktok ?
