how to skip the "Reading pictures. Scanned folders: 1234, scanned files: 60553 so far..."
InGearX
Post by InGearX »
yes I am doing a huge library it's on SSD - but it takes so so long to scan
there must be some way to pre-index / pre-scan the library and avoid it scanning it every time
or maybe there is some other screensaver that you can recommend?
thank you ...
Re: how to skip the "Reading pictures. Scanned folders: 1234, scanned files: 60553 so far..."
The slideshow is supposed to start during the reading process. When the first picture that was not shown before is found. But we do have several reports that screensaver acts the way you describe it. And we do have plans to make it so that there is a fixed, pre-scanned list of pictures that is built in the settings and is shown immediately when the screensaver starts.
InGearX
Post by InGearX »
Maxim wrote: 04 Oct 2022, 10:46 The slideshow is supposed to start during the reading process. When the first picture that was not shown before is found. But we do have several reports that screensaver acts the way you describe it. And we do have plans to make it so that there is a fixed, pre-scanned list of pictures that is built in the settings and is shown immediately when the screensaver starts.
thank you
not sure why I have this issue
maybe because the library is huge
what options do I have for a solution?
thank you
InGearX
Post by InGearX »
maybe because my history file is 134MB big
C:\Users\YOUR-USERNAME\AppData\Local\Endless Slideshow Screensaver\history.dat
YES renaming it (removing it)
FIXED it
I renamed it manually but another option for users is to
Settings > Slideshow > Shown picture history - checkmark [ X ] "Reset shows pictures history on start-up"
PS my library is 443 GB (476,202,534,016 bytes) - 393,731 Files, 3,171 Folders
