Finding Images
jb9999
Finding Images
Post by jb9999 »
Hi
Very impressed with your Picture Finder 3 and the concise responses on the forum -they've helped a lot.
Unfortunately web sites are constructed differently and the same parameters don't always seem to work.
I'm trying to download from http://www.thai-pix.com/ and the thumbnails are contained in
- http://www.thai-pix.com/gallery/thumbna ... m=7&page=4, where the album no and page no change
and the (full) images are contained in
- http://www.thai-pix.com/gallery/display ... m=7&pos=76, where the album no and pos no change depending on image.
The first time ran the project I had some success and retrieved some images (not all) but can no longer download any images. I have tried many options for this site, including all those mentioned in the forum.
Any help would be appreciated
jb9999
Re: Finding Images
This website seems to be very easy for Extreme Picture Finder. You have to create a very basic project with the following settings:
Starting address: http://www.thai-pix.com
Exploration type: Regular site -> Entire site
Target files: *.jp*
This is it. The rest of the settings can have their default values. You can also add several filters to speed-up the process and cut off thumbnails:
tn_
login\.php
report_file
ecard
addfav
&lang=
ratepic
slideshow
If you'll have any problems downloading from this website (or from any other website) - write me and I'll send you a ready-to-use EPF project file.
jb9999
Re: Finding Images
Post by jb9999 »
Thanks for that. Think I was trying to be too smart - seems to be working fine.
Thanks for your prompt reply
jb9999
