asiantolick templates
visteer251
Post by visteer251 » 02 Jul 2022, 17:57
I need help with asiantolick.com.
First of all, I inform you that I have tried to download a post for a particular link by applying the asiantolick templates.
I wanted to receive a picture of the post that was displayed as an address in /post-###/another-name format and had the title.
The images shown were limited and generally 10 to 50 were all I wanted.
However, when you start receiving the link by applying it to the EPF, you start receiving photos of the associated posts displayed at the bottom of the page as well as photos that serve your original purpose.
As a result, I should have succeeded in receiving only 10 to 50 photos, but I received hundreds of photos with various themes.
You only receive unique photos with the title displayed at the top of the page, and you don't want to receive any other photos.
Can it be solved?
Re: asiantolick templates
Post by Maxim » 04 Jul 2022, 12:50
What was the exact post URL? I just tried a couple of random posts - everything worked just fine.
visteer251
Post by visteer251 » 04 Jul 2022, 18:42
Target Link:
https://asiantolick.com/post-15620/the- ... 2020.08.04
* 89 pics
Program version 3.62.0.0
Post by Maxim » 04 Jul 2022, 19:03
Working just fine here. 89 files. Are you sure you have template installed? Is it selected when you create a project? Should look like this:
visteer251
Post by visteer251 » 05 Jul 2022, 04:25
I received epf-db-template-1060.etmpl twice and applied it to EPF, but I don't think it was added.
And I checked the configure project settings manually when I added the link.
I thought the template would be automatically applied when I received the target link if I received the etmpl file and applied it. It was my mistake.
I'm sorry to waste your time.
Have a nice day. :)
visteer251
Post by visteer251 » 05 Jul 2022, 04:34
By any chance, is there any way to modify the template of the project that has already been added to the epf at once or automatically?
If that doesn't work, how can I export multiple project links to a txt file?
I saved hundreds of projects, but it will take too long to modify the template one by one.
Post by Maxim » 05 Jul 2022, 11:10
What kind of URLs do you have in your projects? I need examples.
Right now there is no way to apply settings from the updated template to existing projects. You'll need to create new projects using new version of the template. But if you give me examples of your URLs - I can come up with an easy solution.
visteer251
Post by visteer251 » 05 Jul 2022, 11:27
There is one starting address per project.
The format is as follows.
https://asiantolick.com/post-<number>/<title>
Post by Maxim » 05 Jul 2022, 11:35
You only need ONE project for all those URLs. Just paste them ALL into a new project make sure the project is using the template. All photos will be saved into separate sub-folders automatically.
You can also create projects with tag URLs to download all posts that belong to a selected tag. Or category URL... Or search results. Take a look at the template page for more into. Extreme Picture Finder can automate your download process by A LOT. Creating a project for every post URL is the least effective way of using the program with this website.
